Ir para o conteúdo principal
Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2704 Perguntas Visualizar todos
I have no idea where I can buy this kind of cable
So I was repairing a speaker and I had to replace the aux cable. However this cable has 3 wires inside, a red one, a white one and a black one (these are inside the cable itself). So today I decided to cut open one of my own and I realised it only has a white and a red cable.
So my question is: "Where can I buy that kind of cable?" And how is that sort of cable called?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I assume you are talking about a 3.5mm cable.
Red is the right channel. That's a standard in the audio industry.
In an RCA plug, white is left channel. However, black could also be left. If I were to take an educated guess, I'd go with white being left channel and black being ground.
What I suggest you do is get a 3.5mm plug, and wire it up. Wire each color to the same contacts as the previous cable if you remember where they where. Play it very quietly, and make sure you can hear both channels, as well as correct stereo orientation. No damage should come to your system as long as you play it quietly.
If you are try to wire something else, please attach some images and tell us your exact model and brand.
Esta resposta foi útil?
Pontuação 2
9 comentários:
But is it possible, to buy one of those 3.5 mm jack cables with all 3 wires inside.
por
@stijntech I changed the link. Look at it now.
por
Thank you so much
por
@stijntech If you cut any 3.5mm cable, that is what it should look like. A red, a white, and a black.
por
Do you also have a link from like ebay
por
Exibir mais 4 comentários
Adicionar a sua resposta
Stijn Helmonds será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 61
