Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Icon shows "charged" when not plugged in
Here is another problem that is new on my iPod (I just don't know what's up with it, there are so many failures):
The icon in the upper right corner shows that the iPod is fully charged, the icon with the plug that follows the flashicon, but the iPod isn't plugged in!
So what do I have to do? Anyone an idea?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
thanks for your answer, but these steps didn't fix it.
So I just tried to plug it in and use the windows' "hardware soft removal" (I don't know if it has this name in english) in the taskbar the lower right corner, and it worked!
Esta resposta foi útil?
Pontuação 0
1 comentário:
That's great! I suggest accepting your answer just to close the question
por
Pergunta mais útil
Hold the center button and menu button for several seconds to reset the iPod, if that doesn't work try toggling the hold switch (leave it off when done). If both fail, try plugging into a computer and restoring the factory settings. If all fails, wait for it to run out of charge then charge it again, then turn it on.
Pontuação 2
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 1,694
