Ir para o conteúdo principal
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
20 Perguntas Visualizar todos
Battery indicators always lit
Hello, recently I got JBL Charge 3 bluetooth speaker. Everything is fine except one thing. Battery indicators are always on. All 5 of them. Even in the JBL Connect there's always full bar. I was using it all day and when I came home I charged it. When I put it to electricity only 2 leds were lit and third was blinking. After some minutes all 4 leds were lit and 5th was blinking. The 5th led is blinking endlessly.. Everything works fine except the indicators... I will try to completely drain its battery and recharge it and I'll also try resetting it(power button and volume down). When I got it, it was charged to 4 leds and it was draining( only 3 leds left after some time). I put it to charge and I updated the firmware and leave it to charge. After some time the 5th led was still blinking endlessly but when I took off the charge cable it had 5 leds lit, those were still lit after 3-4 hours of usage...
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Received my NEW JBL Charge 3. When I initially plugged it in for its initial charge there were no status lights lit which tells me the battery arrived with a totally dead battery and it may have expired on the shelf.
The speaker was ordered 25 Nov, Order# 114-0467390-0395426. I’ll bet the battery is new and bad on the shelf. Please inform me on complete replacement of a new battery and replacement instructions. Thank you Bill Martin, Luverne MN
por
Adicionar um comentário
3 respostas
Hello. I had the same problem with a JBL Pulse 3.
I even went to the store where I bought it to replace it (which was kindly done by the salesperson) because I read somewhere the problem was a battery problem.
I charged the "new" unit with the same "defect", but..
But I solved it simply by upgrading the firmware, done through my cell phone.
That was it. No more 5th led blinking eternally.
Esta resposta foi útil?
Pontuação 0
1 comentário:
How to upgrade the firmware?
por
I already updated the firmware. Nothing was wrong with it.. The 5th led just takes too long to charge.. The first 4 leds take about 20 min each, but the third one takes around 2-3 hours. I thought it has defect because I used it for like 2 hours and it still had 5 leds on. When I charged it suddenly had just 3. But now it work fine. Thanks for the answer though. :)
Pontuação 0
1 comentário:
por
my jbl charge 3 is charging for over 4 hours and its still on the 1st led.
what do i do??
Pontuação 0
1 comentário:
Get a better charger.
por
Adicionar a sua resposta
Josef será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 21
Ao todo: 17,025
