Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
Question about Face-ID and replacing the screen.
Hi there, I'd like an answer from someone who has actually replaced the iPhone X screen.
There are some rumours that Face-ID will stop working when you replace just the display, and some deny it.
How was the repair and did Face-ID stop working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If you only replace the SCREEN(don't replace the sensor flex cable), the Face ID will still work. if you replace the sensor flex cable, the Face ID will fail. More about the Face ID repair you can visit here:Why iPhone X Face ID not work after repairing
Esta resposta foi útil?
Pontuação 1
If you replace iPhone 8, 8 plus or X screen you need to copy the firmware data of the original screen into the new screen. The needed tool is under development. I saw some working versions, what are tested and working with IOS 11.4 and 12.0 Beta. The screen data can be cloned only to OEM screens for now.
Afte the copy of the data, the light sensor works well again.
If you would like to know more about this problem read this article: http://www.futuresupplier.com/blog/solve...
Box: http://www.futuresupplier.com/iphone-8-8...
Pontuação 0
Adicionar a sua resposta
nicolay.94 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,055
