Ir para o conteúdo principal
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
49 Perguntas Visualizar todos
Won't charge while turned on and drops charge
I have had my OnePlus 2 phone for two years now. I haven't had any problems with it until recently. It was charging fine but now it won't charge right. I plug it in to charge and the charging light will come on but then it stops charging. The only way I can get it to charge at all is by turning it off and letting it charge that way. But once I have it charged to 100% and go to use it, it drops dramatically. Like for example it'll be at 100% and if I let it sit there and not touch it it drops down to 80% within 2 minutes. At first I thought it was the charger so I got another but it still did the same thing. I haven't bought a new cord as of yet.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
First try a different cord, just to prove that the cord is not the problem.
How old is the phone? I suspect that the battery is failing and needs to be replaced. Even rechargeable batteries have a lifespan.
Here is a link to the ifixit OnePlus 2 Battery Replacement guide.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Anna Trussell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 968
