Ir para o conteúdo principal
Repair guides and support for a wide range of mattresses.
6 Perguntas Visualizar todos
How can I get my mattress repaired?
Can anyone fix a ripped mattress I want it done professionally? I can not seem to find anyone at this time
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I need someone to fix a zipper on my mattress
por
Adicionar um comentário
3 respostas
Solução escolhida
Here's a video on how to do it: https://www.hunker.com/13403914/mattress...
If you don't want to do it yourself, call fabric store and ask if they have a contact.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
A mattress is simply covered in a lot of fabric with a lot of sewing.
Consider researching mobile seamstresses or tailors to see if they are willing to repair the mattress.
Google and Yelp! are your best resources for this.
Pontuação 2
2 comentários:
Is there anyone who can clean a new mattress that has had about a cup of oil spilt on one corner of a new king size mattress?
por
Just use a standard carpet cleaner. Mattresses are large enough that you can run a carpet cleaner over a mattress like you use it on the floor.
por
Yes, you can fix the ripped mattress. Spray inside the tear with adhesive, covering both sides of the tear within the foam; be sure some of the adhesive reaches near the edges to create a lasting bond. Allow adhesive to dry for 10 to 15 seconds, then press the foam sides together, closing the tear. Hold in place for 20 or 30 seconds.
Pontuação 0
Adicionar a sua resposta
Vivian Roberts será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 43
Duração total: 8,149
