Ir para o conteúdo principal
A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
Spot on the display when lifting the frame
Hello,
I'm trying to replace the kindle paperwhite battery (1th gen). When I lift the frame some spots appear on the screen so I will stop. it's normal?
Update (02/01/2018)
@Darwin I took a photos of this spot. Please check pics.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
What type of spot. If it’s like a water mark that’s normal. It means the lcd and the glass/digitizer is touching. If that’s the issue you can use adhesive tape around the frame so that they do not touch each other. If the spot looks like a white spot it could be a pressure point. Check to make sure there is no screws or strange object left in there
Esta resposta foi útil?
Pontuação 0
1 comentário:
Plese check the update. Thanks.
por
Adicionar a sua resposta
Simone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 147
