Ir para o conteúdo principal
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
32 Perguntas Visualizar todos
Installed new power port and Tablet won't turn on, why?
We changed the power charging port following your directions. Great install instructions and no problems. Tablet displayed large green android icon and message "downloading, don't turn off target device." In upper left, displayed message regarding "odin mode." After looking for the answer to that situation, we allowed the battery to completely discharge, then recharged to 100%. Tried holding the power and volume simultaneously. No luck. Still won't reboot and only image now is the full battery. Do you have any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
why did you let the battery discharge when it was only in odin mode, you only had to hold the power button down to turn it off and turn it back on, it would only download if you were trying to reinstall the firmware. try disconnecting the battery and reconnecting it
Update (01/31/2018)
this guide will show you how to disconnect and reconnect
Samsung Galaxy Tab Pro 12.2 Battery Replacement
Esta resposta foi útil?
Pontuação 1
1 comentário:
We replaced a bad power port. "Odin problem" began after we installed the port. The" hold power button" and other button combinations didn't work. We tried letting the battery discharge instead of removing/disconnecting it. How do you disconnect the battery?
por
Adicionar a sua resposta
Roni será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Duração total: 396
