Ir para o conteúdo principal
Fujifilm Finepix S4200 is a 14.0 megapixel bridge digital camera released by Fujifilm in 2012.
On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
por
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
Esta resposta foi útil?
Pontuação 1
1 comentário:
Where can I purchase a new button. My button came completely off?
por
constant problem with these cameras. even lubrication does not help
Pontuação 0
1 comentário:
I put new batteries in the camera and won't come on
por
Adicionar a sua resposta
gazza b será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 44
Ao todo: 2,870
