Ir para o conteúdo principal
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
387 Perguntas Visualizar todos
What's wrong with my playstation 4 Pro?
One day I came home from work eager to get on my Ps4 Pro. I got home, turned it on and nothing. So I pressed it again. This time I watched it carefully and saw the blue light come on and turn right back off. I then checked the socket it was in and saw a dead lizard inside the other half of the socket. Later that day, I opened the Ps4 up and inspected the motherboard. I didn't smell any burns from the mother board nor did i see any issues with it. I am hoping and praying this is not an APU or "New Motherboard" issue because I'm out of luck. I live all the way in The Bahamas. I'm thinking of replacing the power supply but I'm just not sure. Can someone offer any advice?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I really wonder how you got a dead lizard inside your PS4, but that’s none of my business.
It’d be one of these 2 problems:
1) Your power supply is “broken” or malfunctioning due to the lizard. You’d have to check carefully if this is the problem and if so replace the PSU (Power Supply Unit), if that’s even possible.
2) The Lizard caused a short circuit on one of the components in the PS4, I can’t tell which sadly. Check for any parts that look broken or burned (even if it’s a tiny detail). In case of a crucial component (motherboard or other), you’d have to most likely buy a new PS4 Pro.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I checked closely like 3x already. I also checked the power supply. Nothing seems out of the way rather than dust on the power supply. And no the lizard was in the electrical socket. Not the Ps4 itself. But thank you nonetheless. Going to try and order a replacement this Friday. If I can find one that is.
por
By any chance did you find a solution ? Mine started doing the same thing but because of a power outage and I already replaced the power supply but still does the same thing
Pontuação 0
1 comentário:
My issue was the power supply. Yours may be an APU or board issue.
por
I went to power mine on and my game loaded up halfway and the whole console shut down with no message or error warning. Let it sit for around 20 minutes or so, went to turn it on again and did the same thing. Motherboard or APU problem? I've had it about 3 and a half years. If it's gonna cost too much to fix whatever problem it is, I might as well order a ps5.
Pontuação 0
Adicionar a sua resposta
Shaquille Moss será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 486
