Ir para o conteúdo principal
iPhone 6 wifi and bluetooth intermittent issue - still stumped
iPhone 6 doesn't connect to wifi and barely connects to bluetooth and then drops. Tried replacing F antenna cable, changed the bent frame, tried changing the wifi antenna, and still no luck. Could be a chip malfunction?
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
@nickybawb44 Are you always trying to connect to the same devices with your iPhone, or have you tried different devices?
I am asking because are you sure it is the phone and not the other party?
por
I tried connecting by bluetooth to multiple devices and it would still drop after at least 3 meters. After I changed the frame, it would only show one device and drop even quicker.
por
Adicionar um comentário
1 resposta
May sound annoying but try changing the WiFi antenna again, this part sometimes get damaged very easily. If your issue is low signal strength, it an be solved with this antenna.
Esta resposta foi útil?
Pontuação 0
1 comentário:
A couple different F antennas were tried. No change. Thanks though.
por
Adicionar a sua resposta
Nick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,213
