Ir para o conteúdo principal
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
Display issues on Samsung J1
HI there again.
Well, A Samsung J1 is curiosuly switching off the screen when some function is attempted to be used and no matter what I do, the screen, when black, doesn't light up again immediatelly. When so I need to wait till her good will returns and the screeen light on again or disasemble the device removing battery and even though, some times doesn't return requesting again to remove battery till it works.
Recently the acreen is becoming shinny beyond normality but a bit blurry with some winks taking some time (a minute even less).
Besides the belief on a screen problem, this isn't a continuous issue but intermittent one.
Any suggestion?
Thanks + Rgds.
Marco
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Yeah, that's a failing screen. Usually occurs when you put too much pressure on the screen.
Are the colors getting washed out?
Here is a guide to replace the screen if needed:
Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement
Esta resposta foi útil?
Pontuação 0
1 comentário:
Just happened what I was most scared of. Anyway thanks for your help. By the way the screen looks washed.
por
Adicionar a sua resposta
Marco Bella Rosa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 2,057
