Phone glitching, Custom OS warning
My phone randomly turned off. I held the power button, the home button, both of them at the same time, I tried the volume up button with the power button, I basically tried every combination of buttons I could, and it was completely blank. I plugged it in and got a battery charging sign, which alternated with the Samsung logo. I tried volume up + home + power button, and it started alternating between the Samsung logo screen and an "installing systems update" screen. I held volume down + home + power, and got a warning screen about a "custom OS" and it said to press the volume down to cancel it or the volume up to continue with it, but whenever I press one of the two it either immediately goes away or does nothing. It is currently stuck flashing between the Samsung screen and the "installing systems update" screen, both of them flash for about one second and then go away for about two (like the logo will flash for a second, then go black for two, then show the systems update screen, then go black, and it continues). It's been like this for about 2 hours. How do I fix it??
Esta é uma boa pergunta?
7 comentários
Phone was dropped in toilet bowl a month ago there a little water in side phone a week later starts glitching non stop
por bozzlady509
I just had this happen with a blue screen, asking me to install custom OS or cancel. I have rooted phones before and never seen this. I have never even attempted to root my note 8 but saw this and got freaked out like it is a hack. I long pressed power button to reset and it did, but I'm still worried my phone is compromised.
por Jason
My samsung galaxy tablet is doing the same thing but I don't think its battery is replaceable and It is not charged at all and it only shows something when I plug it in please help
por Kwagala Omega
My galaxy S6 did this. Shut down automatically, wouldn't restart. Before this happened I kept getting a pop-up message that a diagmonapp(?) feature wasn't working. Not sure if related. After ph shutdown, I did vol down+power+home buttons 1 at a time & held it for a few secs. It came up w/ the blue download screen. I freaked too. Wasn't sure my ph was hijacked either. After multi attempts to restart w/ the vol down & only got stuck on solid samsung screen, I gave in & did vol up to download. We have super slow upload/download speeds (2/4 on CenturyLink). Not sure if it's my download rate (espec since all are home due to Coronavirus) or something else. My battery seems to charge ok, but runs down quickly. Have to charge it 2x/day. I've been using battery saver mode to conserve energy at night, as it leaves ph/alarms active. I'm disabled, my life is on my phone, it's my lifeline. I've been fairly diligent scan'g w/ antivirus. P.S. Didn't think battery was removable in S6, which was an initial complaint? Are all able to now?
por CC Klavitter
I’ve got a Samsung s6 that’s stuck on the Samsung flashing logo screen, it did this after a factory reset because I’m about to send the phone off after I sold it.
I’ve tried manually factory resetting it and restarting it, nothing.
I’ve soft rebooted it also nothing, the only option that might work is the custom reboot option and it says downloading do not turn off target.
How long does it take to re download and what options do I have if this also gets stuck?
So frustrating!
por robertpaulcornell
Exibir mais 2 comentários
