Ir para o conteúdo principal
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
85 Perguntas Visualizar todos
HyperX Cloud Core, Left ear not working
The left ear on my HyperX Cloud Core stopped working, when i wiggle the wire sometimes it does return the sound for a second. I haven't noticed any problems with the wires which is why this seems weird to me. http://imgur.com/lDjHv6i here is a picture of the left ear inside.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
sounds like there is a break in the cable that leads to the left ear. try narrowing down where the break is by wiggling the cable all along the length of it. once you have found the break point you will want to replace that section of wire. you will need some basic tools for this and some patience as it can be tricky. let me know if you need any more help.
Esta resposta foi útil?
Pontuação 2
Hyper X it´s an expensive phones model and brings problems like a cheap model. I have the same left ear issue and this only has few months of use !!!
Pontuação 0
Adicionar a sua resposta
Egor Matuk será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 7,634
