Ir para o conteúdo principal
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 Perguntas Visualizar todos
Front and Rear Windshield Washers Not Working
The windshield washer fluid will not come out in neither the front or the rear. I checked the fuses and they are both fine. Any thoughts on what it could be? I watched a video on replacing the pumps and they mention there is a pump for each window so I'm not sure how likely it is for both pumps to go out at the same time. Thank you
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Same problem here. Were you able to find a solution?
por
Adicionar um comentário
1 resposta
I had to change both. There on the left side by the front wheel. I went to Ford to replace them.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lucia Munoz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,719
