What is a GPU and what does it do?
What does GPU stand for?
What guide should be followed to replace it?
What part should be ordered to replace it?
Esta é uma boa pergunta?
GPU stands for: Graphic Processor Unit. Technically just the raw chip.
Often we use the term GPU Board, GPU Card or Video Card to describe the full assembly
Here's the guide: iMac Intel 20" EMC 2133 and 2210 Video Card Replacement
Esta resposta foi útil?
What the GPU does, is it renders all the stuff. Or, it turns the computers electrical signals into a visual that can be seen on the screen.
So its like
COMPUTER SIGNALS --> GPU --> DISPLAY
A GPU turns Computer signals into signals a display can recognize and display.
I worded it to make it simple and in my own words
Heres a nice little block diagram of a PC
image found on www.graphicsbuzz.com
why am I including the source? I'm not a sponsor or anything. I don't want to get called out for accidentally infringing copyright again. Also that website is sketchy and gives you Microsoft support scams. Don't go there.
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 111
2 comentários
It might be helpful trying to understand why you think you need to replace it. Can you explain your reasons.
por Dan
I have vertical colored lines when I boot up. I had white screen, then replaced the logic board, but now I've got vertical lines.
por mchlgrblsk
