Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Ram Bank 1 showing that it is empty.
I noticed that about 90% of the time my MacBook Pro shows that only one of the RAM banks works. I have switched the ram sticks to each bank and only Bank 0 reads the stick. Any solutions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You can try removing your RAM and cleaning the sockets with isopropyl alcohol and a toothbrush. If that does not work the only solution I know off is to replace the logic board. Frankly I would just use the one bank instead of spending that amount of money.
MacBook Pro 13" Unibody Mid 2009 RAM Replacement
Esta resposta foi útil?
Pontuação 2
1 comentário:
+ RAM slots do go bad but will sometimes take a smaller meg chip. This is the first I have seen in your model so the cleaning is in order.
por
Chase Bank Hours
Leading Bank in United States of America
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,917
