Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Perguntas Visualizar todos
Replacement Digitisers won’t work
Ok, I have replaced numerous screens but this one has got me. The digitiser is cracked but works , I have tried 5 New digitisers on it but none of them work (except the home button) as soon as I put the old one on (which is not the original either) it works !!
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Thanks , but it is a correct part. The working (broken ) one is one I’ve previously replaced too . It’s really weird, I even thought some of the connector from the iPad could be attached to the ic connector !! But it’s not
por
Adicionar um comentário
1 resposta
This is odd, It's essentially impossible to have 5 bad screens. So if the OG works, the only thing I can think of is that they are the wrong part number. Try confirming it is the exact model and everything is correctly plugged it. I know that's not helpful but that is all I have. Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
dave será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 69
