Ir para o conteúdo principal
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
32 Perguntas Visualizar todos
How to remove motherboard Anfang fix battery connector
I had the same problem as many others with the flickering, rebooting, not charging of the galaxy note pro 12.2 wifi. So I opened the back cover of the tablet and found the battery connector sitting in place but loose. When I touched it a bit too hard it moved and when I tried to push it back it fell apart. Now I have to replace it completely but can find No information on removing the motherboard. I did find a really good video on your website for the 10.1 I believe but my motherboard has a couple of more cable ribbons attached and I am not sure how to remove them.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Here is a guide on replacing the battery if that helps.
Here
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks but I am looking to replace the battery connector and have to remove the motherboard from the tablet to fix it.
por
Adicionar a sua resposta
Wayne De Groot será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 736
