Ir para o conteúdo principal
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Perguntas Visualizar todos
LCD screen blank - but external monitor is working
I have spent some time on your site, and found similar problems I experience. My iMac screen is black to the naked eye, when plugging in a external monitor it works, and shining a flashligh on the screen reveals that my screen is still working, so my guess is the LED driver portion of the main board is faulty, is there anyway I can fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
It sounds like the backlight went out. I usually recommend screen replacement unless you have incredible micro soldering skills. You may have to purchase a damaged unit and use the screen off of it or purchase a new screen. Looks like a new screen is under $200 HERE
And HERE is how to replace the screen
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yes, in my experience it is the backlight.
por
"unless you have incredible micro soldering skills" - is there a component / fuse I can replace on the main board to make this work, from what I can see on other sources and this one, it is mainly a fuse on the main board that needs replacement, I will be more than happy to try and fix it , my soldering skills are not too bad :)
por
Adicionar a sua resposta
Arno Janse van Rensburg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 154
