Why does my Dyson stop working every 3-5 seconds
We have a Dyson DC45. It shuts off (stops working) every 3-5 seconds. Can this be fixed, by myself or at a repair centre?
The Dyson DC 45 ( I have shown DC56 here as it appears similar to the DC45) stops every 3-5 seconds when in use. The following is a more detailed series of the events which occur.
The Dyson is fully charged, when starting use with the brush head attachment, stops working after about 10 seconds of use.
We turn it on using the trigger starter. It stops again after about 3 seconds. We release the trigger and press it again. It starts and runs for approximately 3 seconds, then stops again. The sequence of restarting is repetitive until we give up in frustration.
Is there a "home fixable solution" or must it be taken to a repair shop? If so, where in the Toronto area can it be taken.
Thank you
Esta é uma boa pergunta?
20 comentários
My disown work 3 or 5 seconds and stop working can I do anything L thank you
por carlapereira62
You need to remove the cone shaped filter ‘washing it alone isn’t good enough you need to remove the filter at the thick end there are 2 small clips that you can push in with a blunt knife to remove the filter sock from the frame!! Once you have done this you will see a large amount of dirt trapped in the filter frame remove the dirt wash and dry the filter sock preferably overnight clip the filter back together put it back in the machine and bobs your uncle
por john metrac
I have this same problem. Looked for this cone shaped filter and 2 clips but cant find it. Any help would be great.
por Roxanne Steffens
Mine doesn’t have clips as such - but it has 3 little horizontal slots a few mm wide, that I depressed with the blunt end of a screwdriver. That was enough to pop the frame out of the sock thing, There was a plug of hair and dirt about an inch long and wide, jammed into the bottom/narrowest part of the cone!
por Jessica Innocenti-Lampen
brilliant it worked,why did I spend an hour on the phone talking to dyson and they couldnt resolve it
por fudgec
Exibir mais 15 comentários
