Ir para o conteúdo principal
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
My Amazon TV Firestick won’t turn on an Element TV
I brought my Amazon Firestick to my boyfriend’s house and plugged it into his tv. It won’t turn on at all. I’ve tried both HDMI ports, I’ve tried unplugging it and letting it “boot up”, I’ve tried turning off the tv, I’ve tried changing the batteries in the remote, I’ve tried “resetting” it and nothing is helping. It’s still plugged into the external power source. The screen just says no signal and stays blue. Nothing is popping up. What am I supposed to do?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Go to your TV settings and turn on the HDMI port. Also older models may not be HDCP compliant, like the Element TV (circa 2010?). In that case you'll need an HDMI splitter like View HD VHD-1x2MN3D. It will strip the HDCP copyright coding from the stream allowing it to show on that TV.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Can u show me what one looked like
por
I have my Amazon fire stick trying to hook it up to my nephew element tv how can i get it to start working on his TV
Pontuação 0
2 comentários:
Plug it in to a USB port and plus the power cable to the USB-A port on theTV (if there, must be 5W 500mA (2.5W) or more) or into a power brick (reccomended, ideally 5+watts)
por
@casualgamer Thanks for the contribution, Conner! Minor correction though: *5V* 500 mA, lol
por
I purchased an Element 75 in goggle tv. My amazon firestick isn't working properly. My movies are distorted. What the solution to this problem?
Pontuação 0
Did you try a different hdmi port or the extended port the FS comes with?
Pontuação 0
Adicionar a sua resposta
Codi Sp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 18,929
