Ir para o conteúdo principal
The second generation of Citroen's supermini car was produced between 2009 and 2016.
7 Perguntas Visualizar todos
Why is my gearbox faulting?
I have a strange, intermittent issue, where my car (auto) fails to shift gears within the first 5 minutes of driving, but only during specific conditions. When it fails, there is a lurch forward, and a Gearbox fault digital warning appears. The SERVICE lamp also turns on. All I have to do though is pull over, and restart the engine. None of the warnings come back on, and the car doesn't experience a fault after that.
The problem: My car's gearbox faults
The conditions:
  • Cold, or just warmed up engine.
  • Going up hill
A mechanic has suggested I need a new gearbox - but I'm not sure it's specific to the gearbox itself. Before I spend a bunch of money on a new gearbox, does anyone have any ideas about what this is or how to fix it?
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
For anyone with the same problem. Sounds like it could be this: https://www.citroenc3owners.com/c3-autom...
por
Hi did you find the problem I have this exact same issue?
por
Adicionar um comentário
1 resposta
I needed to change the item below "clutch Actuator" The price is in Dansh Kroner - that solved the problem
LL90118 Slavecylinder, kobling Actuator 1 Stk. 3.399,00 3.399,00
Good luck and happy new year :)
Jan
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hannah G será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 43
Duração total: 3,033
