Ir para o conteúdo principal
The LG G Pad 8.3 is a tablet created by LG Electronics Inc. that weighs 11 ounces, has 16 GB of storage, and has a 8.3 inch screen.
Why won't it shut off?
My g pad is frozen on the secure start up screen. I put in my pattern and it said to shut off and restart to unlock device. But now its frozen. And wont shut down for a hard reset. What do I do?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Hi,
Have you tried holding the power button until it force shuts down?
por
Good morning! And to answer your question, I have held the Power button down for several minutes to no avail.
por
Thank you for the info. I already done that. I believe that the power button is not working. When I got it apart it looked like it had been poked by something very pointed. I believe it either severed or disconected some wires in the ribbon. I would try to jump start it off the board, but can't find the "ground" and don't want to fry it. I can get a new starter/volume button for about 6 bucks.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
If the tablet is still on, then here is the ifixit LG G Pad 8.3 Battery Replacement guide.
Use the guide to disconnect the battery from the systemboard in the tablet. Once it has turned off, reconnect the battery and start again.
Alternatively wait until the battery has discharged enough for the tablet to shut down then fully recharge the battery before attempting to turn the tablet on again.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
william armstrong será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 13
Últimos 30 dias: 34
Ao todo: 1,384
