Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
Need s7 replacement antenna.
“I'm trying to find a replacement antenna for my s7. No luck so far.”
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Galaxy S7 Antenna Cables (Global)
Imagem de Replace the antenna cables that connect the motherboard to the charging daughter board compatible with the global model SM-G930F Samsung Galaxy S7 smartphone.
Produto
$18.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
Is that basically the antenna itself? I guess I was mistaking looking for the antenna module. My signal was intermittently dropping completely, for long periods. . Tried all the possible fixes.
por
Those are just the antenna cables that provide the connection from the logic board to the charging port dock flex daughterboard assembly.
The physical antennas are on these parts which are connected via pong spring connectors on the top area of logic board and the charging port daughterboard.
This is for the charging port area:
[produto vinculado ausente ou desativado: IF329-024]
por
Adicionar a sua resposta
Joe Niman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 963
