Ir para o conteúdo principal
Sky Viper V2450 streaming drone with GPS and autopilot.
Drone not lifting off and leaning towards the left.
I have two Skyviper V2450 GPS drones with autopilot. My twins received them for Christmas and we are having problems getting them to work.
Viper #1- Of the four blades, one of the green blades is not turning properly. The white cogs under the green blade are rubbing against each other and are not turning smoothly. Thus, they are hitting each other vs fitting together to turn. When the drone is turned on to fly, the three other blades try to lift off the ground but the one that is not turning slowing causes the drone to lean to the ground and it does not take off.
Vipe #2 - The cogs on the three of these blades are all skipping. Some times the cogs fit together and run smoothly and sometimes they hit each other as well and do not turn smoothly.
Can the white cogs be repaired?
Esta é uma boa pergunta?
Pontuação 2
4 comentários:
Yor best bet would be to replace the gear sets. Search for them on eBay and maybe Sky Viper site.
por
Gear set from Viper. Currently sold out.
2450 GPS Prop Gears
Your Price: $1.00
Out of Stock.
Part Number:GPS g-Prop
por
I have this same exact problem too, the top left propellor keeps wobbling and it was because the gear below it wasn’t properly aligned to the smaller gear this makes my drone wobble mid flight and sometimes making me lose control because of the wobbling
por
Oops I meant top right propellor
por
Adicionar um comentário
2 respostas
http://replacementparts-skyrockettoys-co...
above is the OEM set straight from the manufacturer. They are currently sold out at the moment, so you would need to contact their store and have them order it in, or find a thrid party supllier.
Esta resposta foi útil?
Pontuação 0
Your best bet would be to replace the gear sets. Search for them on eBay and maybe Sky Viper site.
Pontuação 0
1 comentário:
From sky-viper.com
2450 GPS Prop Gears
Your Price: $1.00
Out of Stock.
por
Adicionar a sua resposta
melleniegoebel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 14
Ao todo: 5,745
