My iPhone 6S keeps turning off by itself.
My iPhone keeps turning off by itself. It also keeps showing that the battery is not charged but turns on and it is charged but still turns off.
Esta é uma boa pergunta?
Hello,
Well everyone is experiencing this and it's also all over the news. This is Apples new software update that helps those who might not have a new battery and is weak to still get performance. You can read about this online and to fix this problem you will need to get a new battery.
Apple are offering a service where you can walk into an apple store and they will replace your battery and you will get the same performance of your phone as day 1 when you bought it. It's for $29 I think. Or you can do it yourself with the Ifixit kits that they are now offering. Here's a link: https://www.ifixit.com/Kits/iPhone-Batte...
Hope that helped
Esta resposta foi útil?
For me, I got a brand new battery a few months ago and have just recently been experiencing this issue. I’m not entirely sure what is causing it, but I’ve observed that my phone won’t do it as often if it is plugged in or around 70% charged.
Just happened to mine, defective battery it swells, brought it in and it was under warranty so they replaced battery free of charge
i have the same problem too with my iphone 6s it keeps shutting off
It continually happens to me when I’m scrolling my facebook news feed. ???
It just happened to me too.
I keeps rebooting by it self. I found a temporary solution to back it up since I haven't backed it up in a long time. The sad news that it doesn't back for some reason it gives incorrect error "cannot back of because there isn't enough space in this computer" which is impossible.( this is another problem tho)
Now help me fix my backup problem please lol
I tried backing up by iCloud through the iPhone but give me the same massage as it did on iTunes.
I just got a new battery about 2-3 weeks ago and mine won’t stay on unless I have it connected to the charger. I have backed it up and reset it back to original settings but nothing is working.
The charging ic needs to be replaced. Microsoldering job!
My iPhone 6s is turning on and going off by itself! what is the course please?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 31,622
4 comentários
so when you unplug it from the charger it turns off? and when on the charger it works fine?
por Aiden
My iPhone 6s Plus keeps randomly shutting off and is very difficult to turn back on.
To try and fix this I have replaced the power button ribbon cable, battery, screen and have also reset the phone to factory settings via DFU mode. All of this has had no effect on the initial issue but instead has caused this to randomly turn the phone off after short use. Even if I can get this switched on again it still turns itself off.
This is driving me insane and I have no idea how to solve this. Could this be software / motherboard issue? Please help?
Jason T..
por Jason Tucker
This is motherboard issue! The charging ic needs to be replaced. Microsoldering job!
por Al Hemani
i also have the same issue as you. i just think that my iphone 6s is too old. so i accept it always turning off. but as time past it will get worser. i suggest you to buy a new phone.
por miarasy
