Ir para o conteúdo principal
Dell Inspiron 11-3162 de 11" nas cores azul, vermelho ou branco, lançado em 16 de fevereiro de 2016.
Why won't windows install
It says windows installation cannot proceed
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Is that all it says? no error code or anything? What type of installation media are you trying to use? disk? Flash Drive? Or OS reset?
por Compartilhar
Adicionar um comentário
1 resposta
I will suggest you to check the BIOS settings provided below to see if you have similar settings. If not you may try these settings and then install the operating system.
  • Go to the BIOS screen by pressing F2 at the Dell logo 4-5 times.
  • Navigate to ‘Advanced Tab’ and select ‘Onboard Device Configuration’.
  • Set ‘SATA Mode’ to ‘AHCI’.
  • Navigate to ‘Boot’ tab and set ‘Secure Boot’ to ‘Enable’ and ‘Load Legacy OPROM’ to ‘Disable’.
  • Boot Mode should be set to ‘UEFI’.
  • Save the settings and Exit from the BIOS.
Once the system restarts, Go to the ‘One Time Boot Menu’ by pressing F12 at the Dell logo 6-7 times.
Select the boot device under UEFI to boot.
In case you have other problems in installing Windows update, check out those methods.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dan groulx será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 22
Últimos 30 dias: 36
Ao todo: 2,087
