Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Perguntas Visualizar todos
My audiojack volume is very low
Hi there,
I recently purchased a second hand Macbook Pro Retina Mid 2014, 256gb.
When I bought it and tested, the audio jack worked perfectly fine. The day after purchasing it, it's gone incredibly quiet. There is sound coming out, the speakers work perfectly fine, but the audio coming from the headphones is so quiet I can barely hear it. I have tested the headphones in a different device and it's def a problem with the Macbook.
I have tried an SMC reset to no avail. Thinking it might need an audio jack replacement. If so, where and how does one do that? I noticed that the audio jacks for this model come with the logic board, is it possible to buy and fit one separately?
Kind Regards,
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Review this IFIXIT guide: MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement jump down to Step26 you can see the headphone jack. You'll want to see if you have any staining or corrosion on the logic board. If you do you may need to get a new logic board. Post some images so we can so how bad it is.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kyle Hill será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 521
