Ir para o conteúdo principal
13" laptop part of Dell's E6000 series, released 2011. The device features a removable battery, optical drive, and is compatible with a variety of E-Port docking stations.
6 Perguntas Visualizar todos
Wireless connection is not working
Hii,
I recently changed my hardware now it shows wireless is not enabled. I tried all the methods but in connections only it is showing only USB not getting wireless options. What should I do for this?? Should I have to install any drivers??
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
Which wireless card did you install? There are certain cards that will not work with this chipset. (i.e. Intel Centrino 6235)
por
Adicionar um comentário
1 resposta
Did the wifi switch on the right side just above the optical drive get turned off? Happens all the time on my latitudes.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Khathijathul kubra será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 10
Duração total: 1,247
