Why can't I hear phone calls unless the speaker is on
I can not hear phone calls placed unless the speaker is on
Esta é uma boa pergunta?
Hi @pbplus313058 ,
Try using the earphones with the microphone attachment and listen if you can hear OK when using them on a call.
If you can and since you can hear OK when using the loudspeaker then most likely there is a problem with the phone's receiver. It's either faulty or has come loose from the systemboard
Here is a link that shows how to replace the receiver in your phone.
Here is a link to some suppliers of the replacement part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
If the repair process seems to daunting, I suggest that you contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 1,751
