Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
705 Perguntas Visualizar todos
Replacing the Digitizer - What adhesive to use?
Long story short, I have scratched the plastic screen on my Nintendo Switch.
I discovered that there are replacement digitizers on eBay and Aliexpress available already. However, it seems that all of them do not come with adhesive preapplied.
Does anyone know what type of adhesive is used inside the Nintendo Switch that is glueing the digitizer onto the housing?
Thank you very much in advance!
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Pergunta mais útil
I purchased a set off of Amazon that came with "tools" and a roll of 1mm double sided adhesive tape. You would just lay a strip down and then pull of the non stick side. Pretty easy to use. The tools is comes with are pretty useless though (bad screwdriver, and doesn't have tri-wing screwdriver).
https://www.amazon.com/KR-NET-Screen-Dig...
Esta resposta foi útil?
Pontuação 1
Only 1 mm, isn't it too little ? Some recommend 3M but never precise the width.
Pontuação 0
Yes It Is Too Little, Had To Order New Strips, Don’t Know What Size yet.
Pontuação 0
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 70
Duração total: 7,548
