Ir para o conteúdo principal
The Toshiba Satellite C75D-A7370 is a mid-range laptop featuring an AMD quad-core processor, 8 GB of RAM, and a 17.3 inch HD display.
2 Perguntas Visualizar todos
Not detecting wifi,tried all,help?
Computer is c75-7310
Windows 8.1- posted previous question tried different suggestions nothing worked.
'Message on troubleshooting
None of the networks you previously connected to are in range...which I am
Also-a network cable is not properly plug in or may be broken...which on wifi...there are no cables...so I'm stumped...been trying to fix this now for over a week,helppp?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
delete device in device manager and click scan for hardware changes and let default driver install , if this does not work download driver from manufacturers website. If all else fails just install a edimax usb wifi adapter for 8 bucks at amazon.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nicole será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 149
