When I hold the power button only the fans turn on
I unscrewed the the bottom of the laptop to dust it off and when I screwed it back the laptop won't turn on except for the fans
Esta pergunta é pertinente?
What did you use to dust it off? Canned air can cause liquid damage, compressed air can have water in the line or be too strong. A vacuum can give of a static discharge. I use an electric blower, and a tooth brush.
Also try unplugging the laptop and removing the battery and holding the power button down to discharge the electricity.
Esta resposta foi útil?
I used a feather duster to dust off the whole thing and a toothbrush for the fans
did you ever find a solution to this? I just ran into the exact issue without even taking it apart to clean out
i fixed it by unplugging the battery and then re-plugging it again. you're gonna have to unscrew the bottom of the laptop to do that.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,113
1 dos comentários
Did you ever find a solution to this? I just ran into the same issue
por Matthew Waldmann
