Ir para o conteúdo principal
Support for tablets by Coby, including the Kyros line.
65 Perguntas Visualizar todos
Factory or hard reset for Coby kyros mid8020
I forgot the password so I am locked out. I have tried numerous attempts holding power button, back button, volumne - button, power, volume, home button and I have reset it over and over but get no where except to the screen after coby and android logo's which is where you type your password. I have searched the internet but can't find any support what so ever. Any help you can give me I would be thankful
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
At the very beginning hold down the Power rocker for a short while in order to turn on the device.
After that, go the Menu and find and select Settings.
In the next step choose Backup & Reset and tap Factory data reset.
Then choose Reset device and select Erase everything to confirm the whole operation.
or
Android tablets by Coby allow users to lock their devices using a pattern screen lock. If you are unable to log into your Android tablet, or have forgotten the pattern screen lock, you can either reset the lock pattern through Google or restore your tablet to the original factory settings.
Attempt to unlock your Coby Android tablet at least five times. After the fifth attempt, a message will display on-screen explaining you were unsuccessful at unlocking your tablet.
Tap on the option to make an emergency call, then quickly press the Lock / Power button on your device.
Press the Lock / Power button again within 30 seconds, then tap on “Forgot pattern?”
Sign into the Google account associated with your tablet.
If you are unable to sign in to your Google account, follow the steps outlined in method two of this article to reset and unlock your tablet.
Draw a new lock pattern, then tap on “Continue.”
Draw the new lock pattern a second time, then tap “Done.” Your Coby Android tablet will now be unlocked.
https://www.wikihow.com/Unlock-a-Coby-An...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Caroline será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 3,018
