Why is one of my propelers is not working
Every time I turn my drone on one of the propelers won't work
Esta é uma boa pergunta?
Pontuação
0
Do you still have it?
There is a screw that goes through the propeller and the shaft, on the bottom gear you have the same set up. the screws will shear in the shaft preventing a simple replacement. You may have to drill out to free the broken screw inside the shaft, through the top worked for me
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 365
It could be the screw that holds the propeller to the shaft; sometimes the break
por lild.james
