Ir para o conteúdo principal
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
20 Perguntas Visualizar todos
Epson SX445W not working
No problems to date with printing or photocopying . This morning turned on to photocopy but it didn't work. Message now reads "printer error. Turn power off and on again" every time I switch it on. Help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Check the cd tray flap is all the way in....Secondly use the USB port that you first used when you installed the printer....otherwise the computer may not recognise it....if you find front USB ports are not always responding to connections..consider using the rear USB ports as these connect directly to maotherboard and are more reliable.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jeconuk será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 262
