Ir para o conteúdo principal
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Perguntas Visualizar todos
Display switches off when opened more than 45 degrees
Hi
I have a late 2016 13.3" MBP with function keys. Lately, I've been facing an issue where the screen will go black(dim) when its titled more than 45 degrees. It's out of warranty as well
I am still able to make out the contents on the display using a flashlight. Went to the Apple Store, they want to replace the entire display assembly and are asking for $650 dollars for the same
Is there any fix for this?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
We don't have any guides yet on the new 2016/17 MacBook Pro's. But the teardown can give us a clue on whats happening MacBook Pro 13" Function Keys Late 2016 Teardown. If we jump down to Step19 we can see how this series inter-connects the display and the logic board. One of these ribbon cables is likely damaged in some way.
Carefully pop off your bottom cover and do an inspection of the connectors do you see any staining from liquid damage? Do you see any distorted parts or missing screws? Take some images so we can see if you see anything.
Most of us tech's haven't seen them yet as most issues are still covered under warranty. Do be careful as this still maybe covered under an extended warranty issue (defective part type of issue) so you don't want to mark your system that you've been in it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I haven't yet collected the laptop from the diagnostics. Will try and attempt to check once I get it back
por
This sounds Like a defective Lvds cable.
The lvds cable carries the backlight signal and video signal within the cable
if there is a loose connection in the cable wiring it will cause the symptoms you are having
As a hobby i fix apple computers and i had a problem with a lvds cable that had severed video wires internally. The computer only presented a white screen when turned on no apple logo because it was only showing the backlight and no video signal
Pontuação 0
7 comentários:
How do I check for the LVDS cable connection?
por
open the back and disconnect the cable where it goes into the logic board then hook up the mac to your tv if it works ok the i would be 99 percent sure that it
when moving the screen like you say the broken cable shorts back together when less than 45 degree displaying a normal screen i would find a good used one on ebay and try it if ur computer is not under warrenty
por
im very confident this is the problem
por
Jack - This is a very different configuration!
First the cables (2) carry iDP signaling not LVDS. All of the Retina systems use iDP signaling.
The cable interconnection is what I pointed to in my answer above.
por
ok well i'm saying the cables would most likely be the fault then from my experience they both do in theory the same thing supply backlight and video
por
Exibir mais 2 comentários
Adicionar a sua resposta
Saurabh Jain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 20
Duração total: 4,965
