Ir para o conteúdo principal
The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
104 Perguntas Visualizar todos
Why did my vibration motor stopped working, even after it was replaced
Hi, after about a year of use, my Google Pixel's vibration motor ceased to work properly. I could still feel a faint buzz on the motor, but it doesn't rumble strong enough like it used to. I order a replacement part from iFixit and successfully replaced it myself, but after just a day, this motor exhibited the same problem. Is there anything I can do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Nigel Rodriguez After you replaced the parts what did you do? did you run the test to your Pixel?
Did you format the device after you replaced the parts?
*You need to format the device after you replaced the parts...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nigel Rodriguez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 43
