Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
At what point should I consider replacing my battery?
I am curious when I should replace my battery. It can hold 92% currently, but in light of recent Apple CPU throttling concerns, I would like to know at what point it needs to be replaced. Thanks!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
Need? whenever your phone is unable to support your schedule.
however, batteries are only designed for roughly 500 charges. so anytime after a year and a half would be the optimal preventative timing to replace a battery.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Even new it isn't able to support my schedule. Just a tiny battery. I think I might replace it as it has been more than 500 charge cycles. Thanks for your feedback!
por
I have completely rewritten this comment, so Reed Crosby's comment may not be exactly coherent with my comment.
I found what I think is an/the early note on reddit about this at https://www.reddit.com/r/iphone/comments.... So, although we don't know what exactly triggers the throttling (battery cycles or capacity or age or ?), we do know a way with either CPU Dasher X or comparative Geekbench scores to see if you are being throttled.
I did a cursory security check on CPU Dasher X (no big red flags when searching the web, it looks like there is open source code on github for some version of it), downloaded it, and found that I am not throttled (CPU speed very close to max). The coconutBattery application (runs on your computer but will check you phone's battery when connected) says my phone's battery is still above 95% / 1545 mAh at only 257 cycles, even though the phone is 15 months (about 450 days) old. I would guess it is capacity or cycles based, as it seems like I might get throttled on age alone. I'll comment back here if I notice a change and remember to come back.
Update at the 27 month mark for my iPhoneSE:
I have been throttled or had sudden shutdowns occasionally for a couple of months. My battery status since then (January 2018)
2018-11: 83-85%, for a couple of readings around 400 cycles. No problems.
2019-05: 84%, 483 cycles. Consistently down here, but still okay.
2020-01: 83%, 626 cycles, about when problems started
2020-03: 83%, 661 cycles, still usually gets me through the day unless I use it a lot.
I just ordered a replacement battery kit. In part because of the problems for the last couple of months, but mostly because I just dropped my phone in the water. I fished it out quickly, dehydrated it for about an hour a couple of times but saw some symptoms when I checked after each of those. Dehydrated it over night and it seems fine, but I want to crack the case, check on it, and clean up. Figured the battery replacement went along with that.
Pontuação 1
1 comentário:
@public1 I saw the original reddit discussion, but I can't find it a second time and have been unable to figure out what triggers the throttling. 11.3 allows you to switch it off now so not that big of a deal.
por
You can always add a Mophie Battery charging case to extend your battery life. However if you must change your battery I would do it when it will only Charge to 75 %.
Pontuação 0
Adicionar a sua resposta
Reed Crosby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,013
