Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone 5s touch screen digitalizer not working after screen repacement
i replaced broken screen of my iphone 5s.. after repacement the touch screen digitalizer not working .. itried the new lcd on another iphone 5s.wit ios 11.02. it works pefectly.. my iphone has ios 11.1 and it not works in my iphone ..and old broken screen works fine... is that ios problem????
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I don't think it's iOS problem but it doesn't hurt to try updating the phone, backup your phone on iTunes before updating it just in case it bricks and you need to update or restore.
Esta resposta foi útil?
Pontuação 1
So your old broken screen works fine on your phone right? I think it could be ios issue. I was havingproblems with a home button on an iPhone 6, screen worked great on every other iPhone I put it on but any screen I put on the original the home button just wouldnt work. I restored, updated, and bam. Magically fixed. I read that some after market screens were having issues with some iOS 11 updates. I would update the the newest software and see what happens. You should see the problem solved after an update and possible restore to factory settings. In my opinion I would restore to factory settings. Only to see if that fixes the problem. Then if it does, restore from previous backup.
Pontuação 1
2 comentários:
it is an aftermarket diplay. i factory reset the phone but ..no responce
por
update to latest ios 11.2.1 ... not fixed touch issuue
por
Thanks for posting a detailed guide on this. This is really helpful. Terrarium Tv Apk Latest
Pontuação 0
Adicionar a sua resposta
Shuhaibu Kh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 199
