Ir para o conteúdo principal
Guias de reparo e suporte para o Leap, um smartphone de 5" que utiliza o sistema operacional BlackBerry 10.
red light keeps blinking
my blackberry leap just red light blinking?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
my fone says bberror,doesnt wanna switch on
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
If the light blinks twice fast then slow 3 times but never turns on, it means the device is soft bricked. This happens when the OS is corrupted or somehow the wrong version of the OS has been flashed on (Like I did). You will need to do a factory reset to bring it back to life.
Esta resposta foi útil?
Pontuação 1
3 comentários:
how do u do the factory reset
mine is bricked as u say but i dont know how to flash or whatsoever
por Compartilhar
when connected to pc it says no device
por Compartilhar
i try the factory reset is not working
por Compartilhar
im assuming the device itself does not boot up for this, because the red light blinks when you have notificationas as well.
If you plug your device in to a PC, and it is recognized, you likely have a screen failure.
If it is not being recognized, then i would start to think you have further issues. Red flashing LED indicates a general hardware failure, which could be most anything. (battery, camera, etc) most commonly however, it is a board level failure.
Pontuação 0
Adicionar a sua resposta
Anthony Enriquez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 4,309
