Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
20 Perguntas Visualizar todos
No sound during video recording
Hi everybody. A problem with Iphone 7 which isn't recording the audio during video recording with back side camera. When using front camera recording has no problem on audio and plays both normally.
Thanks in advance for the help.
Esta é uma boa pergunta?
Pontuação 5
11 comentários
so everytime i record a regular video on snapchat or the actual iphone camera app, and i go to watch it no sound will come out. i turned up the volume and tried exiting out of the app, turning it off and also restarting my phone and still no sound will come. any help?
por
This happens to me too
por
this has been happening to my phone too, and i can’t fix it. but on top of that when i make calls i cant hear anything and the speaker button looks disabled. even when i ft me or the other person will accept it, but it disconnects. it’s been a big issue lately and really annoying me.
por
this is definitely the issue with the audio ic. replacing the audio ic should fix it. most of the iphone repair places don't offer this service since it's not an easy job to do.
por
Have a look at this https://youtu.be/MjWGmfWsh9Q if this doesn't work then you will need to replace the ic
por
Exibir mais 6 comentários
Adicionar um comentário
11 respostas
Pergunta mais útil
I Have this problem too but i’m also unable to use my phone to make calls without using wireless headphones. Plugging headphones into the charger port dosn’t work either. I’ve actually changed the charger port ( which involves a complete stripdown of the phone) and it’s made know difference at all I think it’s probably a mother board issue.
Esta resposta foi útil?
Pontuação 5
6 comentários:
I’m having the same exact problem and i have no idea how to fix it SOMEONE please help!!
por
when on a call, is your speakerphone option grayed out? your issue sounds more like a board failure these devices are sadly known for
por
thats happening to me what do i do i just got this phone
por
So did you find a solution?
por
I have a YouTube channel and I cant make videos with out audio if u want to check it out The Fingerboarder 2823
por
Exibir mais 1 comentário
Hi Marco,
Nearly no sound when recording Videos with back camera an answer for the same problem with the iPhone 6, might be a place to start. Between that one and this one (also for the 6, unfortunately), I'd say there's probably something covering the rear microphone.
This thread mentions a problem with the iPhone 7 specifically, but it sounds like theirs is an intermittent problem, whereas yours just doesn't record the sound. Does your iPhone still have the protective cover on the back?
Pontuação 3
3 comentários:
Hi! Rachel. No, item doesn't have such cover. In fact this issue started short time ago. Thanks for your help.
por
I see. Is it not recording any sound at all or is it poor quality, intermittent, etc? Also, is it still under warranty?
por
Actually it's recording normally when only audio is recorded and when front camera is used. Only when uses the back camera doesn't record at all. Also is playing a huge noise sometimes and none of the sounds produced during shooting of some videos are recorded.
por
I think IPHONE is toilet, My Samsung from 5 Years ago I know records video & Sound perfectly, after a while that’s why IPhone wants you to upgrade, corporate B.S in my opinion, next upgrade will be Samsung
Pontuação 1
1 comentário:
Do you REALLY think this is a constructive comment for this person who is seeking this answer?
por
I am also having same problem on my iphone 7 Plus. Recording a video doesn’t record a sound. Any solution to it will be helpful to me.
Pontuação 1
1 comentário:
por
I have almost the same problem with my iphone 7.
So when I drop it in the bed, or just hit a little bit with my finger, the camera does not record, and the sound disapears it starts lagging, even when you try to record on snapchat it kinda freezes. When i restart everything is working untill i accidently hit or sometimes it starts by itself
Pontuação 1
2 comentários:
that’s the same with mine.
por
This is literally the EXACT same with mine!!! Except when I reset it it doesn’t work. But my audio doesn’t work and video on snap lags so hard like doesn’t even record. And I happened after I dropped it like 100 times ahaha :((
por
Both front and back has no sound
Pontuação 1
for this issue, attempt a factory reset first I would say. it sounds like the microphones should be working which leads me to think it’s more likely a software glitch
Pontuação 0
3 comentários:
I’ve already reseted my phone but it still doesn’t work
por
So we all have the same problem w no solution? My 7 is doing this too &’ I can not afford another phone at this time
por
Me too , I’ve got iPhone 7 and %#*@ can’t make video calls as no sound at all I someone calls me it won’t answer when u hit the green answer “button” I can decline the call no problem :/ so annoying and this is my business phone . Apple you better solve this problem soon ! I’m not sure if it’s got anything to do with almost no memory left on the phone ?
por
That is the Audio ic issues that some pin are broken under Audio ic.
Pontuação 0
Thanks man for your support. Appreciated.
Rgds
Marco
Pontuação 0
this is definitely the issue with the audio ic. replacing the audio ic should fix it. most of the iphone repair store don't offer this service since it's not an easy job to do.
Pontuação 0
2 comentários:
So what’s the problem?
por
So how much is the audio ic?
por
Brand new iphone7-have the newest update(13.?)
No sound on iPhone video I just took
Pontuação 0
1 comentário:
I have the same problem too after video recording sound there is no sound while play record..iphone 7 plus ios 14
por
Adicionar a sua resposta
Marco Bella Rosa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 66,760
