Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Custom icons have reverted to blue folders
Upon updating to High Sierras, all but a handful of my custom desktop icons reverted to the standard blue folder icons. When I go to download new custom icons and follow the replace procedure (open, get info, copy image, paste image to replace blue folder image), this is what happens: I select "get info" and all I get is a "preview" icon. I tried copying and pasting that, but if I do, the "preview" icon becomes my folder's image. I have no idea why this has happened, nor how to fix it.
Any suggestions?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
What is your system model?
por
It is a new iMac Intel 27", Retina 5K, 3.4GHz.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
In the older OS9 we often needed to rebuild the desktop as the data structure between the icon & application/data file ID would get messed up as they where held in different structures. In OS-X & MacOS there is no means to rebuild the icon to file association as the data file is now one structure.
Sadly I suspect your drive has some issues!
So what to do??
First make a proper backup using TimeMachine (we don't want a image clone).
Next create if you don't have one an external bootable drive a USB thumb drive will work. A bootable OS installer drive will also work as you may need to re-install a fresh OS. Follow this guide: How to create a bootable macOS High Sierra installer drive
I might add if you have a SATA SSD drive I would recommend you stick with MacOS Sierra as Apple's new APFS has issues with SATA based SSD's (remember High Sierra forces you to upgrade to APFS)
OK, You now have the bootable drive Boot up with it and then run Disk Utility from it. Don't use the onboard recovery services diagnostics as it can't alter the deeper levels of the drive. If the drive can't be saved you'll need to reformat it and install a fresh copy of OS.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I greatly appreciate your answer. However, I do not believe the drive has issues. This is a new computer. All else works perfectly. Only the folder icons reverted to the plain blue folder icons.
However, I am not doubting what you said. But since this is under warranty, I would rather make sure that what you suggest sound correct to Apple technicians, which it very well may.
The problem is, is that SOME icons (they were part of a set -- different exotic flowers) work FINE, as do other random ones. This is a mystery to me. So, it is not across the board. That's what so odd about this.
por
I said your drive has issues, that does not mean you have a bad drive! Your OS is corrupted here.
I would follow the steps I outlined here or bring it in to an Apple Store and let them deal with it.
I would also recommend you double check your power outlet you are using for your system. Make sure its properly grounded and you might want to get a UPS as the power may not be stable enough (a possible cause of your corruption).
por
Adicionar a sua resposta
Tatami 53 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 601
