Ir para o conteúdo principal
Does iPhone 6s ios 11 activation failure may be related to hardware?
I've updated my iphone 6s to ios 11 since last week. However up until today, i'm still unable to activate, hence use my phone. Restored to factory setting countless time, but still not to avail. Always failed at the "activation server cannot be reached" thingy. I know the server might be busy, but for the whole week? Connected to laptop and itunes, but an error popped up saying that I need to put the simcard correctly (eventhough the phone picked up the cellular signal perfectly) so i cannot activate it using itunes either. So, back to my question, is there any chance that this is a hardware issue? If yes, which part was damaged or need to be repaired? thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Sometime iTunes makes fail to activate use 3utool for activation with supported sim.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks. Will try it. Is the software free? Or do we have to pay to unlock all function available?
por
Yes that is absolutely free
por
Have you tried updating iTunes? If that still does not work try installing it "manually" http://appldnld.apple.com/ios11.1seed/09... (iOS 11.1 ipsw file for iPhone 6s)
and then use these instructions provided by OSX Daily:
1. Connect your iPhone or iOS device to your computer
2. Select the device in iTunes
3. On a Mac, hold down the “Option” key and then click on “Update”
4. On a Windows PC, hold down “SHIFT” key and then click on “Update”
5. Select the IPSW file you downloaded and click “Choose”
6. Let the iOS device update as usual
Pontuação 0
2 comentários:
Hi. Thanks for the response. I’ve already done the steps before. And still can’t activate the phone. Cannot connect to apple activation server.
por
Do you have another PC?
por
Adicionar a sua resposta
Iman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 544
