Why is my phone not changing
I have a blu VIVOXL my phone went dead for one day I tried changing it and it's not holding a change it won't ever turn on. Why is this happening?
Esta é uma boa pergunta?
There is so many chances the phone is going on dead.
Most common factor.
-Longlasting charging more then need.
-Use powerbank.
These are necessary but caution on use.
You have t open the phone and check the phone is shorting or battery nill and unable to charge or charging connector might be faulty try to clean it.
That clearly shows that is hardware issues.
Esta resposta foi útil?
Hi,
You can try these ways.
Charge more than 30 minutes to have a try.
Use other charger and data cable.
Clean the dirty in the charging port.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 62
