Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
Pergunta encerrada
This accessory is not supported by this iPhone? after reassembling
Completely dis assembled this Iphone 3gs, re assembled, tested all other features. Only problem i am coming upon is this message about not compatible accessory.Ive double check all cables, connections, etc. It will only play music through the headphones but will play notifications through the speaker so both work. It some how is registering a accessory without one being there, which is interfering with music being played though speaker. Any help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
try cleaning the dock connection/usb port with a soft brush to remove lint and dirt-often builds up here from putting your iphone in your pocket, stops devices recognising your iphone. Try this before you decide to replace SYSTEM connection???
Esta resposta foi útil?
Pontuação 1
I've come across that before, change the SYSTEM connector and it should resolve the issue. :)
Pontuação 0
1 comentário:
but it didnt seem to do this before according to what the person says. So no one thinks thats its improperly re assembled? Just went through it for the 5th time, i can do it with my eyes closed now a days. So im pretty confident in my ability to work on these devices, just wanna make sure i dont lose my edge lol. THanks for all your guys help.
por
change the dock like Ifixit said and my phone still has the same warning "accessory not supported. What a waste of money!!!!!
Pontuação 0
I know this is an old thread, but, just in case somebody is having this problem today and is searching for any answers, my 3GS had this problem but no more. Basically I narrowed it down to the electrical outlet being used. I didn't believe it at first but after trying different outlets in my house the same thing happened. So try different outlets. I suspect some outlets have more electrical noise than others thus confusing the IPhone. Even try an outlet at somebody elses house.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,689
