Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Home button continuous vibration
Good day, I have an iPhone 7 which the screen was replaced but now the Home button is just continuously vibrating. When I press and hold the button it just goes into a vibrating frenzy, this happens whilst holding the button. If I press the button as per normal it is like I am pressing the button Three times. Has anyone encountered this and possibly know of an easy fix for this?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
I have had two problems that are exactly like this..
Number 1 was waterdamaged and number 2 was just a damaged home button, and sorry to say you cannot fix an iphone 7 home button without soldering. Replacing it renders the home button useless.
Esta resposta foi útil?
Pontuação -1
1 comentário:
down vote because you don't like the answer, nice.
Go back to where you had it fixed and tell them to check the homebutton.
por
Adicionar a sua resposta
Paul Naude será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 1,608
