Ir para o conteúdo principal
I phone 6s motherboard replacement with a new block iPhone 6
Hi everyone , I am currently using a iPhone 6 s . Recently having problem with its touchscreen , the lower bar of the screen is compleatly not working , and battery is down , show charging sign but doesn't change the percentage number with keep restarting .
On the other hand I have another iPhone 6 with network block so I can't use it .
To not that my faulty iPhone is 16 gb but the other one is 64 .
So is there any solution that I can change the motherboard of my block iPhone from my old one and use it ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi if you manage to do this you are a magician.. forget about this.
It would be easier to fix the original iphone 6s, test a new screen and battery would be a good start
Esta resposta foi útil?
Pontuação 0
The components are not compatible between those models. I recommend a new screen and battery as first steps.
Pontuação 0
Adicionar a sua resposta
Arif será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,186
