Ir para o conteúdo principal
Slow battery charge
Battery charging slowly
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
How long does it take, and did it used to not take that long? How long does it work once charged? You may want to download Coconut Battery:
http://www.versiontracker.com/dyn/morein...
This free app with give you some basic information on your battery and its status.
Anyway, please provide some more basic info as to what's going on, and then we can give more specific advice. If you have a different battery, you may want to try that one in order to determine if the computer is the problem, or the battery -- if it similarly charges slowly, the problem may be the computer, whereas another battery charges quickly, then the problem is likely the original battery, etc.
Thanks
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
William McNulty será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,713
